Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
rebar not visable
0 REPLIES 0
Message 1 of 1
kevms
220 Views, 0 Replies
rebar not visable
Hello All
This is the first time I have run into this error.
I have a concrete slab and have modelled it with the area reinf however when I cut a wall section partially thru the slab I have noticed that the rebar is not visable. I have created a couple of other similar sections and they are fine.
I checked the visability graphics for anything turned off and/or if a filter is applied but everything looks good.
I also noticed I don't have a problem placing rebar parallel to the work plan or cover. I only have this problem placing it perp to cover. Sketching rebar is okay.
I am not sure where else to look.
Hope someone can provide a fix, I am sure there is a check mark somewhere I need to check or uncheck.
Thanks in advance
Kevin
Using Revit Structure 2012, 2013, 2014
I think I am getting the hang of this revit stuff
0 REPLIES 0
