Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
rebar issues in Revit and Robot
0 REPLIES 0
Message 1 of 1
502 Views, 0 Replies
Hi
I've made a simple model with 2 diferent solutions:
Have placed grids in floor plan and put the colunms by the place on grid method.
Have placed the beams in level 2 bt the same method, but in case 1, I have deleted the 2 beams created and replaced by one beam from one of the colunms to the last one.
I've send the model to Robot to create the reinforcemnt and have updated again to the revit model.
Now is the issue:
Why when I have made the beams by place in grid (Case 2, beams are created between each colunm) the rebars go outside of host, and in case 1 not?
Some kind of configuration that i've must have in Robot?
Or is something else?
Tags (3)
0 REPLIES 0
