Revit Rebar Detailing is so frustrating. So good in many ways, but I just can't get the drawings to look correct.
Forinstance:
How can I do varying length bars?
How can I place a bar range that is skewed to the concrete face?
How can I place a thick line on the end of the bar range without making the leader line thick also?
Why do bar lengths keep changing by a few millimeters, and Rebar tags keep moving even when I pin them?
Why can I not tag bar ends properly?
I don't really think I will get an answer to these questions. Time to go back to Autocad I think, before I loose my clients.
Solved by SOFiSTiK_RS. Go to Solution.
Have you tried selecting the tags in entire project at once and giving them a nudge? One to the left, one to the right, like the song. I wonder if that would work...
I think the tags behave like that when the rebars are copied/mirrored, can't recall for certain that...
Im also facing the same issue when opening a linked file and reloading the model file linked with sheets file
"Rebar tags keep moving even when I pin them".
Is there any solution without using third party applications.
