Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
railing dimension
1 REPLY 1
mortel09
323 Views, 1 Reply
railing dimension
How can i make a circular rail with the dimension 48,3x4 ? i have tried to open a new family with the rail template, but i cant change the thickness of it...
1 REPLY 1
fernanda.firman
in reply to: mortel09
To change the dimension of the railing you will have to:
1. Open the rail family profile
2. Change the dimension
3. Load the profile into the project
When the family is loaded:
1. Select the railing
2. Go to Edit type
3. Under the profile select the new profile you just loaded
Hope that hellps
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
