Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
quantities
2 REPLIES 2
253 Views, 2 Replies
quantities
I am new to revit and I have researched this quite a bit before posting. As you can see in the first screenshot i am able to get the total volume for the walls which is all i am after. I cannot get the same result from the footings and slabs. What am I doing wrong. I have three options for a building and i just need total volume for the walls and footings (and slabs).
2 REPLIES 2
I found it. Formatting tab, calculate totals. If anyone has any insight or best practices on what i described please feel free to chime in. thanks.
Try to use "calculated value" by getting the product of Area and Thickness. Adjust units accordingly.
