Morning
Is it possible to import/convert a Revit file into PV SOL?
Regards
Ian
Solved by alan.quinn. Go to Solution.
What is PV SOL? I did a search and found lots of into on PV panels etc.....
Thanks for posting.
Alan
Link to the PV SOL software.
http://www.solardesign.co.uk/pvsol-expert.php
Hope this helps.
Ian
I would suggest that you ask the vendor. See here http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/2171-Print_Ex2171... for a list of way to export from Revit. Ask the vendor if it will accept any of file formats list in the above link.
Thanks for posting.
