Revit Structure
Valued Mentor
JohnHolder
Message 1 of 8 (413 Views)
Accepted Solution
publishing to DWF and NOT buzzsaw
413 Views, 7 Replies
02-04-2013 11:50 AM
I just hope I am just seeing the option, but is there anyway to publish to DWF and not to buzzsaw?
I can <print> to pdf, but I rather use DWF.
John.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Hi. Just a suggestion. You can simply export to DWF using the export option in the application menu. You will end up with one DWF file for the entire project.
KateMorrical
Message 2 of 8 (407 Views)
Re: publishing to DWF and NOT buzzsaw
02-04-2013 01:31 PM in reply to: JohnHolder
You could grab the Autodesk DWF Writer (Windows system printer driver) and use that with the Print dialog.
Kate Morrical
Digital Design Manager
Washington, DC
BIMmuse.com
Valued Mentor
JohnHolder
Message 3 of 8 (398 Views)
02-04-2013 02:00 PM in reply to: KateMorrical
unfortunatly all it does is make 0 kb files.
Personally I think it kind of silly, that I have to download a program to print/publish in dwf when everything else that I have from autocad does it natively.
and the 32-bit program of course does not install since I have a 64 bit machine.
Master Yoda.
Valued Mentor
AJA14
Message 4 of 8 (389 Views)
02-04-2013 09:53 PM in reply to: JohnHolder
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
KateMorrical
Message 5 of 8 (382 Views)
02-05-2013 07:32 AM in reply to: AJA14
A much better suggestion than mine. :-)
Kate Morrical
Washington, DC
BIMmuse.com
Valued Mentor
JohnHolder
Message 6 of 8 (374 Views)
02-05-2013 08:55 AM in reply to: AJA14
Ok that worked.  Still odd that you cannot publish to dwf.   But a solution!
Master Yoda.
Valued Mentor
JohnHolder
Message 7 of 8 (373 Views)
02-05-2013 08:55 AM in reply to: KateMorrical
No no yours was a great suggestion, and It should have worked!    There may be underlining problems to why it didn't.
Master Yoda.
New Member
AlekseyRusaev4889
Message 8 of 8 (14 Views)
10-12-2014 02:51 AM in reply to: JohnHolder
You can publish to buzzsaw with any settings. but without login/password. and press publish. When you'll see window to enter login/password - do not close it. Your *.dwfx file will be there: C:\Users\\AppData\Local\Temp\ Copy your *.dwfx to any place and then just close window for login/password
Post to the Community
New Post
Need installation help?
