Revit Structure
Active Contributor
allscan12
Message 1 of 3 (126 Views)
Project North vs True North
126 Views, 2 Replies
04-27-2008 12:13 AM
I am following the procedure in RS2008 HELP menu regarding rotating my Project North to True North.
From tools - shared coordinates - specify coordinates at a point -- I specified the coordinates of a certain point and all the coordinates were in proper location then from View Properties - Orientation - true north - I rotated my plan using the normal rotate command but the problem is my coordinates change its numerical data.
Using the view properties again to return back to project north - its not in proper coordinates anymore.
Am I missing some procedure here?
Any help and suggestions will be greately appreciated.
Best regards,
Allan
New Member
wondful
Message 2 of 3 (126 Views)
Re: Project North vs True North
05-04-2008 07:37 AM in reply to: allscan12
what's your intention? It seems shared coordinates is used in linked model and the second rotation will cause the coordinate system change.
Active Contributor
allscan12
Message 3 of 3 (126 Views)
05-04-2008 09:17 PM in reply to: allscan12
Kindly surf this web site for more info.
http://forums.augi.com/showthread.php?t=65874&highlight=true+north
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
