Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Project North vs True North
2 REPLIES 2
acantos_arup_uk
326 Views, 2 Replies
I am following the procedure in RS2008 HELP menu regarding rotating my Project North to True North.
From tools - shared coordinates - specify coordinates at a point -- I specified the coordinates of a certain point and all the coordinates were in proper location then from View Properties - Orientation - true north - I rotated my plan using the normal rotate command but the problem is my coordinates change its numerical data.
Using the view properties again to return back to project north - its not in proper coordinates anymore.
Am I missing some procedure here?
Any help and suggestions will be greately appreciated.
Best regards,
Allan
2 REPLIES 2
in reply to: acantos_arup_uk
what's your intention? It seems shared coordinates is used in linked model and the second rotation will cause the coordinate system change.
Kindly surf this web site for more info.
http://forums.augi.com/showthread.php?t=65874&highlight=true+north
