Revit Structure
Valued Mentor
AJA14
Message 1 of 10 (453 Views)
Problem with revit extensions
453 Views, 9 Replies
02-16-2013 04:22 AM
Hi. This is what happened when trying to add reinforcement for columns using the extensions. Any ideas.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Product Support
Artur.Kosakowski
Message 2 of 10 (405 Views)
Re: Problem with revit extensions
02-20-2013 01:28 AM in reply to: AJA14
My assumption is that you still work with the original 2013 version of REX. Please try to download  and install its newer version (2013Q3) where this issue should be corrected. The newer version replaced the older one on Subscription site.
Artur Kosakowski
Valued Mentor
AJA14
Message 3 of 10 (373 Views)
02-20-2013 05:51 AM in reply to: AJA14
Hi Artur. I downloaded the updated extensions but still facing the same problem. I don't have this problem with other projects so I don't think it is only related to the extensions.
This is a 30 floor tower with a central file and 5 locals and about 8 worksets. Do you think that this could be the cause of the problem.
Ali Al-Hammoud
Product Support
Artur.Kosakowski
Message 4 of 10 (367 Views)
02-20-2013 06:00 AM in reply to: AJA14
I can't tell without having a chance to check. Could you try to isolate the column where this happens and save it in a 'new' Revit file. If you still have the same situation attach this file.
Artur Kosakowski
Valued Mentor
AJA14
Message 5 of 10 (342 Views)
02-21-2013 05:21 AM in reply to: Artur.Kosakowski
Hi. Artur. Take a look at the attached file. If you notice that the revit extensions will not work eventhough all I have is one column and a sheet.
However, what's weird is that if I delete sheet from the project browser and then use the extensions, it works.
Regards.
Ali Al-Hammoud
Product Support
Artur.Kosakowski
Message 6 of 10 (328 Views)
02-21-2013 06:28 AM in reply to: AJA14
I can't see such problem.
Artur Kosakowski
Valued Mentor
AJA14
Message 7 of 10 (320 Views)
02-21-2013 07:23 AM in reply to: Artur.Kosakowski
That's really strange. Like I said, when I delete all my sheets, it works fine. Anyways I'll let you know what I find out.
Ali Al-Hammoud
Product Support
Artur.Kosakowski
Message 8 of 10 (314 Views)
02-21-2013 08:04 AM in reply to: AJA14
Please check which version of REX you have installed as shown on the attached picture.
Artur Kosakowski
Valued Mentor
AJA14
Message 9 of 10 (289 Views)
02-23-2013 09:35 PM in reply to: Artur.Kosakowski
Hi Artur. I have a different version. See attached image. Although I did install the latest from the autodesk website. Could you please provide a link to the correct version. I would really appreciate that.
Regards.
Ali Al-Hammoud
Product Support
Artur.Kosakowski
Message 10 of 10 (270 Views)
02-25-2013 12:45 AM in reply to: AJA14
It is available from the Subscription site (see the attached picture).
Artur Kosakowski
