Hi
I try to import a revit file into advance Concrete so I decided to use the plugin Graitec BIM connect.
In revit when I select Export and run the plugin revit sends me an error message : " graitec BIM Connect encountered an error. We are sorry for the inconvenience".
I tried to export a gtcx file and a gtc file but the result is the same..
I also tried to export another revit project but always this error message.....
I run revit 2015 AC 2015 but I have GraitecBIMConnect2014 because I didn't find the 2015.
Something weird is the automatic software launch (see below) because I can't choose AC but the only option is Advance Design.
How can I do this export?
Thank for your help!
Dear Alexandre Sabatier,
Revit 2015 and AC 2015 do not work with Graitec BIM Connect 2014.
Please install the Advance Steel and Advance Concrete Revit® Plug In - 2015 version, that can be found here:
Please let me know if the information / suggestion I provided helped you.
I will be waiting for your reply.
Best regards,
Emy
