There is a problem while exporting from revit to cad- while exporting the annotation text with leader arrow from revit to cad , the family in cad is expolded elements , the arrow head line are all expolded element , actually in cad the annotation arrow head and the line should be one single block
Solved by CoreyDaun. Go to Solution.
Unfortunately, due to the level of difference between the two programs, the translation from Revit to AutoCAD is far from perfect and any exported DWG will be accompanied by flaws such as this one.
