Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Problem in project browser in Autodesk Revit Structure 2013
1 REPLY 1
aradinie
748 Views, 1 Reply
Dear sir...
am a new user in Autodesk Revit structure 2013 , when i open the program and start to creat levels , the Elevations (Building elevation) is invisible the project browser , so i can not creat the levels, please see attached fileRevit stuc.2013.png
1 REPLY 1
CoreyDaun
in reply to: aradinie
In this case, it appears that the Elevations Views simply do not exist in your Project. This is likely the situation If the Project was started without selecting a Project Template. Go to View Tab » Elevation to create a new Elevation View.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
