Revit Structure
Revit Structure
Active Member
aradinie
Message 1 of 2 (453 Views)
Problem in project browser in Autodesk Revit Structure 2013
453 Views, 1 Replies
02-12-2013 06:22 AM
Dear sir...
am a new user in Autodesk Revit structure 2013 , when i open the program and start to creat levels , the Elevations (Building elevation) is invisible the project browser , so i can not creat the levels, please see attached fileRevit stuc.2013.png
CADastrophe
Message 2 of 2 (451 Views)
Re: Problem in project browser in Autodesk Revit Structure 2013
02-12-2013 06:36 AM in reply to: aradinie
In this case, it appears that the Elevations Views simply do not exist in your Project. This is likely the situation If the Project was started without selecting a Project Template. Go to View Tab » Elevation to create a new Elevation View.
