When creating a partition wall, the following messages appeared:
" Highlighted walls overlap. One of them may be ignored when Revit finds room boundaries. Use Cut Geometry to embed one wall within the other." or
" None of the created elements are visible in 3D View: {3D} View. You may want to check the active view, its Parameters, and Visibility settings."
What`s the problem ?
Solved by 5kings. Go to Solution.
Sounds like a simple visibility issue. Likely causes are:
See if any of the above is the cause. If not, just reply back.
A partition wall is a non-bearing wall. So it won't show up in your default 3D view... or in nother views with it;s discipline on Structural. Change the disipline of the the view, or the structural usage of the wall.
Regards Jordi
Can you detailed instructions with pictures? I don't know how. I draw the outside but i can't draw on beam.
Helio,
I'm get a similar error "Highlighted walls overlap . One of them may be ignored when Revit finds room boundaries. Use Cut Geometry to embed one wall within the other."
I stared with Brick & CMU Cavity Walls. I had to build a room with 4 walls of that type. I later had to remove (trim) one wall which was located on the interior (this is going to be a stairwell) and replace it with a custom wall type. That all worked out well except when I tried to copy that custom wall onto a new level. I'm following the Architectural commercial Revit book. I've tried removing and replacing the wall, changing the wall type and I still get the same error.
Does anyone know what I may be doing wrong??
Thank U
D
