I am trying to set up PDF plot sheets for various sizes. I.e.. Acrobat Distiller 24x36, 30x42, etc… I did input various sheet sizes and saved as independently, but when I reopen the same file and tried to make PDF files selecting one saved plot sheet name under set up it's showing 8.5 x11 sheet under preview. Even selecting 24x36 setup, it's not keeping previously set sheet size under 'postscript custom page size'. Am I missing anything. Is there any different option to set up and save custom sheet size for plotting?
Appreciated for any direction.
Thanks.
Outside of RST, what is your default printer set to?
When you first open up the print dialog box, what is your printer set to? if you change it to Adobe Distiller, and then choose one of your saved plot setups, does it still revert back to 8.5x11?
Yes, I set printer to adobe PDF. The problem is it's not saving 'Postscript custom page size'. Every time I have to define
page size even after selection plot setup.
Thanks for your response.
Hmmm... I'm not sure I follow why you're having to set up "Postscript custom page size." I have a bunch of sizes already listed for me to choose from.
This is where I set my plot set-ups:
picture: revit_adobe print 1 shows, after I choose my printer as Adobe PDF, I go to <Setup...> in the Settings section.
picture: revit_adobe print 2 shows, I choose my paper size (also choose all my other settings) then do a <Save As...> and name it with my actual dimensional size (so I know that an Arch E1 is my 30x42.) Once I have it set up, I hit OK here. it takes me back to my first dialog box. I now have a <Close> button in place of the <Cancel>. I save my file and the plot setups are ready for use.
Maybe you need to set up the custom sizes in the Adobe distiller (outside of Revit) so you have them to choose from once you're in Revit?
Thanks for looking into it and direction.
It appears Postscript custom size is not working in Revit. It was working in autoCAD.
I created custom paper sizes separately in Adobe and then save it to related printer and it's working fine.
Thanks a lot.
