Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Placing a model on a toposurface
1 REPLY 1
stgauss
269 Views, 1 Reply
Topographer gave me survey data the other day in DWG format. Great. I simply import into Revit, toposurface, building pads, everything works.
But, now comes the building model, which should be placed on the toposurface. The question I have is, what's the best way to place an architectural/structural/mep model on the toposurface?
The problem I have is that the topo data has regular old altitude data. So I get a toposurface which is 1200 meters in the air. The architect simply builds his model on a zero level. First floor is 0, second floor is 3 meters up, and so forth. So I end up with the building 1200 meters below the toposurface.
What comes to mind as a solution is creating a new blank project, and linking the building and the toposurface to it. Then I simply use the move tool on an elevation view to pull the building up to the correct altitude, or pull the toposurface down to zero altitude.
But, I assume there´s another, easier way I haven't thought of, that's normally used to line up models and toposurfaces?
Tags (2)
1 REPLY 1
scott_d_davis
in reply to: stgauss
Try the Relocate Project tool:
http://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/ENU...
Scott D Davis
Sr AEC Technical Specialist
