Solved by Chris.Aquino. Go to Solution.
At this time, it is not possible to insert OLE objects directly into Revit. If you need to insert a Word or Excel document, you can insert it into a .dwg, then link that dwg.
We understand that this may not be the preferred workflow, but this issue is already logged with our Development group.
I tried linking an AutoCAD file containing an Excel sheet. Revit strips the OLE object every time. Is there a setting that I'm missing?
