Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Non Vertical Wall
2 REPLIES 2
3532 Views, 2 Replies
Non Vertical Wall
i am trying to create a concrete wall that is set 25 degrees off vertical - is this possible in 2013 and how. I have tried to rotate the wall, set a sloping reference plane and align to it etc. but nothing seems to work.
2 REPLIES 2
Joe.Charpentier
You will need to make a mass that has a face at the location of the wall that you want to create.
Go to the "Massing & Site" tab to create the mass, then use the "Wall by Face" command on the same tab.  This is the best option if you wall type has multiple layers.
The other option is to create an in-place wall. (Strucutre Tab>Component>Model In-Place>Wall Category)
Note that neither of these walls will have an  analytical model.
Joe
in reply to: Joe.Charpentier
Thanks for the help, I was starting to think that a sloping wall was not possible.
