Solved by jachyme. Go to Solution.
Hi, it should be possible without any problem if you use Aligned MRA.
If you attach a sample file I could have a look...
Hi jachyme. Thanks for your help
Problem is with Links Identity Mark 07 in section "RW8 Base"
I have tried deleting the bar and redrawing, but it made no difference.
File is attached. It was frustrating deleting irrelevant details in order to get the file size down, only for the file size to increase.
Stewart
Hi, the only thing I can recommend you is to use, in this particular case, Building Section instead of Wall section. It is strange but on my computer it works fine.
