Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Multi Rebar Annotation Bar Range Extents
1 REPLY 1
stewartg
657 Views, 1 Reply
Hi again - A client has critisised the bar range style I am using. He does have a good point.
Is there a way of defining a user defined tick mark at the extents of the bar range.
This is defined in the dimension style of the Multi-Rebar Style. So I guess what I want to do is change the tick mark in the dimsion style to a user defined shape. Or change the witness line lineweight without changing the lineweight of the main dimension line
I have attached a couple of screen shots that probably don't help at all.
Hope this makes sense
Stewart
1 REPLY 1
Rafal.Gaweda
in reply to: stewartg
For now it is not possible.
We will consider adding such possibility in future versions of Revit.
Thank You for suggestion.
Rafal Gaweda
