Hi again - A client has critisised the bar range style I am using. He does have a good point.
Is there a way of defining a user defined tick mark at the extents of the bar range.
This is defined in the dimension style of the Multi-Rebar Style. So I guess what I want to do is change the tick mark in the dimsion style to a user defined shape. Or change the witness line lineweight without changing the lineweight of the main dimension line
I have attached a couple of screen shots that probably don't help at all.
Hope this makes sense
Stewart
Solved by Rafal.Gaweda. Go to Solution.
For now it is not possible.
We will consider adding such possibility in future versions of Revit.
Thank You for suggestion.
