Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Multi-part WF Column Management
2 REPLIES 2
456 Views, 2 Replies
We have a number of multi-story buildings with multi-part WF columns. For example, a seven story structure with a column that graduates from a W14x109 to W14x90 to W14x61.
I would like to have this work as a single member when moved, copied or rotated. I would like an instance parameter that copies with the column so that every one of it is noted and tagged "C1"
If I "group" the column parts together it detaches from the grids with the flag "A structural element will be detached from grid(s) due to inconsistent group membership." If I copy the group, the mark number goes blank on the new column.
Is there a method for a multi-part column that has a tag that copies with it, and stays attached to the grid system?
2 REPLIES 2
I am having the exact same problem.
Joe.Charpentier
You should be able to do this with assemblies: (in 2012 and 2013)
Select the columns you'd like to move/act together and make them an assembly.
Make the category "column"
Create an assembly tag that meets your needs, and tag the assembly instead of the column.
Joe
