Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Modified Faimly Issues
2 REPLIES 2
TTIII
293 Views, 2 Replies
I'm fairly new to revit, I was trying to find a way to modify a family and I'm having some issues.
I found this link: http://revitrandoms.blogspot.com/2011/09/family-catalogues-in-excel.html
So I modified the contents of
C:\ProgramData\Autodesk\RST 2015\Libraries\US Imperial\Structural Columns\Stee\W-Wide Flange-Column.txt
And it says it cant read them:
,W##other##,A##area##inches,d##length##inches,bf##length##inches,tw##length##inches,tf##length##inches,k##length##inches
W44X335,335,98.5,44.0,15.9,1.03,1.77,2.56
W44X290,290,85.4,43.6,15.8,0.865,1.58,2.36
W44X262,262,77.2,43.3,15.8,0.785,1.42,2.20
W44X230,230,67.8,42.9,15.8,0.710,1.22,2.01
Whats wrong?
Tony
2 REPLIES 2
okapawal
in reply to: TTIII
Save your txt catalog file with ANSI encoding instead of  Unicode.
You will see there are some additional 'question mark' characters in the header which make the problem:
bf##?length##inches
tf##length##inch?es
Delete them, or just use this header line:
Waldemar Okapa
Sr Product Owner
TTIII
in reply to: okapawal
I copied your header as changed my save option in UltraEdit to ANSI\ASCII and it worked.
Thanks a bunch!
