Revit Structure
Member
bteskey
Message 1 of 3 (185 Views)
Metric Project Units
185 Views, 2 Replies
10-31-2012 03:07 PM
Hi Everyone,
In our metric projects we dimension and annotate using millimeters.  On an elevation view we use meters as to show the elevation.  I was thinking we could add some type of function in the elevation label family to divide by 1000 but I'm not sure how I would control the number of digits after the decimal.  I apologize in advance, I broke the cardinal rule I posted on here before I exhausted my own trials.  I was just hoping I may have overlooked something and this is a common case.
Brad
Hi there. What you need to do is duplicate the dimension and create a new type, then edit type, in the text properties click on unit format, clear the checkbox for use project settings, and change the unit to meters instead of millimeters. This does the trick. Remember to create a new type first or all the dimensions of that type will change to displaying dimensions in meters.
For level annotions (level heights) see attchments. Just follow the 2 steps.
Jordi
Valued Mentor
AJA14
Message 2 of 3 (179 Views)
Re: Metric Project Units
10-31-2012 10:18 PM in reply to: bteskey
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Active Contributor
5kings
Message 3 of 3 (173 Views)
11-01-2012 02:08 AM in reply to: bteskey
Jordi
