is it possible to link an ACad drawing showing a vertical section into a Revit elevation. I am trying to setout a stair and want to check the landing lavels etc. I have an Acad drawing showing the cross section and want to insert this into a vertical section through the revit mstair model. is this possible??
Solved by AMosienko. Go to Solution.
