Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Line Weight in Section
3 REPLIES 3
JFN_KSH
2981 Views, 3 Replies
I'm fairly new to Revit Structure. I'm trying to customize our template so the drawing look like our compagny stds. So far, using object style I was able to modify the look of our plan views.
But how do you change the lineweight & color of objects in a section at medium or fine setting?
3 REPLIES 3
in reply to: JFN_KSH
Just collapse Model Objects Category—then overwrite Projection and Cut Line Weight sub-categories you want.
JFN_KSH
i think I follow what you are saying (I'm a newby). So I've change the visibility/graphic overwrite so that all the structural framing is set to color green. As you see in the attach image, this is not working, evrething is still set to color white...
What am I missing?
Thanks for your reply!
CoreyDaun
Try doing the same thing with the Category "Structural Columns" or any of the other ones.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
