Revit Structure
Valued Contributor
Jean_Francois_Nant
Message 1 of 4 (759 Views)
Line Weight in Section
759 Views, 3 Replies
07-12-2012 08:29 AM
I'm fairly new to Revit Structure. I'm trying to customize our template so the drawing look like our compagny stds. So far, using object style I was able to modify the look of our plan views.
But how do you change the lineweight & color of objects in a section at medium or fine setting?
engr_mondo
Message 2 of 4 (751 Views)
Re: Line Weight in Section
07-12-2012 05:23 PM in reply to: Jean_Francois_Nant
Just collapse Model Objects Category—then overwrite Projection and Cut Line Weight sub-categories you want.
Mondo
Valued Contributor
Jean_Francois_Nant
Message 3 of 4 (741 Views)
07-13-2012 10:21 AM in reply to: engr_mondo
i think I follow what you are saying (I'm a newby). So I've change the visibility/graphic overwrite so that all the structural framing is set to color green. As you see in the attach image, this is not working, evrething is still set to color white...
What am I missing?
Thanks for your reply!
CADastrophe
Message 4 of 4 (734 Views)
07-13-2012 10:34 AM in reply to: Jean_Francois_Nant
Try doing the same thing with the Category "Structural Columns" or any of the other ones.
