I'm fairly new to Revit Structure. I'm trying to customize our template so the drawing look like our compagny stds. So far, using object style I was able to modify the look of our plan views.
But how do you change the lineweight & color of objects in a section at medium or fine setting?
i think I follow what you are saying (I'm a newby). So I've change the visibility/graphic overwrite so that all the structural framing is set to color green. As you see in the attach image, this is not working, evrething is still set to color white...
What am I missing?
Thanks for your reply!
