Hi All,
I am using Revit Structure 2011.
Can anyone help me with trying to show my levels to 3 decimal places. At the moment I have my levels showing in sections and elevations in meters to 2 decimal places. I would like to change this to 3 decimal places.
Any help is great.
Solved by raghavendra.bhat. Go to Solution.
Hi John,
Please check your projects units and modify the rounding on lenght:
Thanks for getting back to me.
I have tried what you said, but it has not seemed to make a difference.
When i view an elevation, the level is shown as 1.98m, where as in the Properties box it is shown as 1975.000mm. Do you know if there is a way that will allow my levels on the elevation to show as 1.975m or 1975mm?
Thanks again for your help.
John,
Can you add here a capture of your elevation and project units ?
Try doing this ............
in the Browser select the respective Level and open it for editing
Now select the Elevation Label and edit it
now in the "Edit Label" dialogue box
Select the elevation parameter and click on "Edit parameter units" at the bottom
Now in the Format dialogue box change the precession to three decimal places.
save the settings and load back the family in the project....you will see the difference in precession 😉
Hope you have followed the procedure...let me know if you have any problem fixing it. 🙂
also try to togel and use this
