Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Levels to 3 decimal places
7 REPLIES 7
Message 1 of 8
simpson.john
18422 Views, 7 Replies
Hi All,
I am using Revit Structure 2011.
Can anyone help me with trying to show my levels to 3 decimal places. At the moment I have my levels showing in sections and elevations in meters to 2 decimal places. I would like to change this to 3 decimal places.
Any help is great.
7 REPLIES 7
Message 2 of 8
jad.dellel
in reply to: simpson.john
Hi John,
Please check your projects units and modify the rounding on lenght:
Jad DELLEL
Sustainability Success Manager - Autodesk, Inc.
Message 3 of 8
simpson.john
in reply to: jad.dellel
Thanks for getting back to me.
I have tried what you said, but it has not seemed to make a difference.
When i view an elevation, the level is shown as 1.98m, where as in the Properties box it is shown as 1975.000mm. Do you know if there is a way that will allow my levels on the elevation to show as 1.975m or 1975mm?
Thanks again for your help.
Message 4 of 8
jad.dellel
John,
Can you add here a capture of your elevation and project units ?
Jad DELLEL
Message 5 of 8
Try doing this ............
Now select the Elevation Label and edit it
now in the "Edit Label" dialogue box
Select the elevation parameter and click on "Edit parameter units" at the bottom
Now in the Format dialogue box change the precession to three decimal places.
save the settings and load back the family in the project....you will see the difference in precession 😉
Hope you have followed the procedure...let me know if you have any problem fixing it. 🙂
Raghavendra Bhat,
rnbhat1@gmail.com,
Revit Architecture 2010 Certified Professional.
Message 6 of 8
also try to togel and use this
Raghavendra Bhat,
rnbhat1@gmail.com,
Message 7 of 8
That has worked. Thanks so much for your help on this.
Message 8 of 8
aaronBWC
in reply to: raghavendra.bhat
Perfect, thanks!
