Good Morning , Evening
Please indicate how to do something like the png attached.
thank you
Solved by SteveKStafford. Go to Solution.
Use a void to cut the slab?
There are many ways to accomplish this, as the posts above indicate.
You can aslo use the Slab Shape Edit tools to create a dpression in the slab- the sides will not be perfectly vertical, but you can get it so close nobody will notice- until you try to dimension from edge to edge.
Other than that option, to do this in Revit requries more than one piece of geometry. (Slab+Void or 2 Slabs)
Joe
Shape Editing won't give you a uniform edge like in the image.
