Revit Structure
Member
ola.gunnar.skippervik
Message 1 of 6 (204 Views)
Length of Divided Path
204 Views, 5 Replies
08-08-2012 07:28 AM
I have made a adaptive railing component (RST2013). Addaptive points with a reference line (spline) through the points. I'm interesting in listing the lengt of the Divided path that I've made of this reference line (since this is the lengt of the railing). When I select the Dividet path in the family editor the length is grayed out in the property window. Ideas anyone, how to get this information accessable in my project?
Distinguished Contributor
subpartner
Message 2 of 6 (185 Views)
Re: Length of Divided Path
08-13-2012 05:19 PM in reply to: ola.gunnar.skippervik
It could be that you are not selecting the right layout method.
Please check out htis document:
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0135-Prelimin135/0204-Conceptu204/0...
Member
Message 3 of 6 (178 Views)
08-13-2012 11:52 PM in reply to: subpartner
I'm using fixed distance, as layout method. But it is the total length that I am not able to list, or put in to a parameter or read when I have plased my railing component, (which then have its unique length). This is a "read-only" parameter, and I don't see how changing the layout method will change my chances to list this parameter.....
Product Support
fernanda.firman
Message 4 of 6 (160 Views)
08-15-2012 07:08 PM in reply to: ola.gunnar.skippervik
You are right, the Lengh parameter is a ready only and can't be modified.
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
Member
Message 5 of 6 (155 Views)
08-15-2012 11:45 PM in reply to: fernanda.firman
My intention is not to modify it, but to read it/acces it so that i can know my total length of railing........ Any ideas?
Product Support
fernanda.firman
Message 6 of 6 (122 Views)
08-28-2012 09:09 AM in reply to: ola.gunnar.skippervik
When you select a "Path"in the proprierties dialog box you will see that the "Lenght>Path Lenght" is exactly the lenght of the line you drew and had it divided.
Please check the image.
That value can't be changed but it reads the real value of the segment.
Hope this is what you were refering to.
Autodesk, Inc.
Revit Clinic
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
