After i setup window server 2012, revit server 2014, I can make a host (role, accelerator, admin) to manage some revit file between vitual and real machine (on the same computer). It's ok. (with an attached image : case_1)
After that, i try to connect to that host from a difference computer. and look for it but it's false (case_2)
I don't know how to connect a random computer to above server.
Please help me ! Thanks you guys !
Revit communicates to Revit Server on port 808. Can you ping to the Revit Server from the workstation? Can you telnet via port 808 to the Revit Server? Make sure the firewall allows ports 808 and 80 on both the servers and the workstations. hth.
