Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Issues with Coping of Steel Elements
1 REPLY 1
karunakaran1991
502 Views, 1 Reply
I got a scenario with coping of steel elements, the coping distance is same for all face and direction in revit.
I need some thing different like this image below, the coping distance at central section and flange, its little bit smaller compare to other faces.
This is what I got it from Revit,
Have anyone meet this kind of issue before and how you solved? Attached DWG and RVT file for refference.
Tags (1)
1 REPLY 1
For now there are two solutions:
1. Modify family by adding voids and then you can fully parameterized such cut
2. The fastest method : cut By Face. Example video below
Rafal Gaweda
Rail Community
