I got a scenario with coping of steel elements, the coping distance is same for all face and direction in revit.
I need some thing different like this image below, the coping distance at central section and flange, its little bit smaller compare to other faces.
This is what I got it from Revit,
Have anyone meet this kind of issue before and how you solved? Attached DWG and RVT file for refference.
Solved by Rafal.Gaweda. Go to Solution.
For now there are two solutions:
1. Modify family by adding voids and then you can fully parameterized such cut
2. The fastest method : cut By Face. Example video below
