Revit Structure
Active Member
paulo
Message 1 of 2 (116 Views)
Insert Data the Volume in Tag
116 Views, 1 Replies
01-30-2013 06:50 AM
Problems in Revit Structure.
I have a beam that takes its volume appear on the tag, but this volume is only possible through the properties of the element.
How to solve the problem so that this information appear in tag?
Valued Mentor
AJA14
Message 2 of 2 (101 Views)
Re: Insert Data the Volume in Tag
02-03-2013 05:21 AM in reply to: paulo
Hi. This is what I have done in this case.
Create a shared instance parameter called Volume in the beam family. Use a formula for that parameter = b x h x L.
Add the shared parameter to your tag formula and place it where needed.
Done.
If this solves your problem, please accept as solution.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
