Hi
I am also very keen to use Revit Structure for bridge design, mostly for
flyovers. Currently there is one problem with modelling: Revit does not
allow beams curved in 3D (horisontally + vertically). As vertical
curvature is normally small, we can handle it with straight elements.
Hopefully this will be addressed in next version.
It would be great to reference road and terrain models to Revit or
connect alignment and profile data.
Raul
Douglas2000 wrote:
> The 3D road surface has been exported from 12D to Autocad as 3D string lines and as a 3D tin surface. I have tried to create a mass in Revit using both of these but can't achieve what I would like.
> I would like to use the 3D civil design as a reference point that I can base the setout of the bridge upon.
> The bridge has concrete abutments, piles, wing walls, with precast deck units, concrete deck slab & steel or concrete barriers.
