I'm using the tekla add in, in revit structures 2013 to import an ifc file from tekla 18. everything comes through fine except all column elements are missing. has anyone else had the same thing, and does anyone know how to fix this?
Sounds like the translation converts their columns to architectural columns. If you are using Revit Structure, these will be hidden by default. You may want to go to a 3d view and click the lightbulb at the bottom to see if they are actually there and just not visible.
