Can you please advise how to import a 2D or 3D .dwg file into Revit so that the elements are editable? In other words, so that you can select a vertical line drawn as a column in the dwg file and give this column section properties in Revit. In this way, the dwg is not a background and you do not need to redraw the column. Many thanks.
Adam
Solved by Rafal.Gaweda. Go to Solution.
It is not possible
http://autodesk-revit.blogspot.ch/2007/11/importing-3d-dwgs-into-revit.html
