Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
IFC export
3 REPLIES 3
734 Views, 3 Replies
IFC export
Can Revit Structure 2008 export the loads thru IFC format? If so, how? I can see in the IFC import/export settings menu that many IFC categories are not exported. How can I enable these?
3 REPLIES 3
Yes, same problem by me.
Some column/beam can not be recognized
I think many of us are trying to export the Revit model to analysis softwares without direct link connection. The IFC format could be an option since it is capable of recognizing many structural elements (and boundary conditions, loads, etc.) I am really curious about Autodesk's intention in this subject. Will the IFC import/export option develop in the future? Is the preferred way for connection is through the API? One major problem with the direct link is that the analysis software and Revit Structure needs to be on the same computer and it is often not the case.
Any ideas from anybody?
As a programmer I get a little frustrated when users assume that a
limitation of one software provider is a limitation of the process. In the
UK we are used to separate CAD technicians and Engineers and each user
spending days working on their part of the model before needing to send it
back, so we export a file from one application and import it into another.
This way it does not matter if the 2 apps are on the same computer or not.
wrote in message news:5726846@discussion.autodesk.com...
