Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
IDSP 2014 and Revit Structure
6 REPLIES 6
neilyj666
829 Views, 6 Replies
just upgraded to IDSP 2014 from civil 3d 2013 and Revit Struvture is one of the suite packages. Can anyone explain what I could use Revit Structure to do as it looks like it requires a whole new type of workflow compared to how Civil3D/AutoCAD work.
Are there any useful tutorials that people would recommend - I'm not sure if I would ever use Revit but I'd like to know what it is capable of mainly for my own interest....
thanks
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
6 REPLIES 6
DarrenP
in reply to: neilyj666
how autodesk uses it that i have seen is with the bridge modeling function with the bridge modeler extenstion installed
something like this: http://www.youtube.com/watch?v=ZMiWClmUPSg
DarrenP
neilyj666
I'm hoping it can be used for a bit more than that. .....:)
kathryn.langan
What kind of work do you do? The Revit platform is different from AutoCAD based software. Here are some links to basic tutorial videos that might give you a better idea:
Revit Structure Tutorials
You can do a search on YouTube and you'll find a lot more content. There is an Autodesk YouTube Channel, or you can take a look at one of the many user-created videos that are great too.
It would probably be a good idea to contact your Reseller too to see if they can help show you benefits you could find using Revit Structure.
Katie Langan
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
neilyj666
Mainly earthworks on which other infrastructure is built and although I'm unlikley to use Revit in anger, I'd like to know what it does and how it could be used e.g. visualization etc.
Thanks for the links, I'll check them out
MikeEvansUK
Neil, In our case it will only use aditional space on your hard drive and memory if open.
It has no real benifit to Civil 3d (ground / highway) whatsoever, It handles / creates surfaces like a 3 y/o child colours.
Import your model as a surface and it is simplified and no longer displays anything useable (no breakline functionality).
The only possible crossover could be Retaining walls but then again I tend to design them in Civil3d corridor models from polylines as it's less hassle.
So unless you are both a civil & structural engineer "under the one hat" not much you can do with it apart from open look at it and close it. Navisworks is better for that.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
neilyj666
in reply to: MikeEvansUK
Thanks for this - pretty much my conclusion too
