Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
How to Update Rebar in a Revit 2011 Model from ISM Repository
1 REPLY 1
fbratton
636 Views, 1 Reply
I used a Revit 2011 model to create an ISM repository, which I subsequently used to create a RAM Concept model for slab design.  After designing the slab in Concept, I was able to update the repository with the rebar information, with all of the rebar showing up as a property called "Rebars" in the "Properties" table for the slab.  I can also view all of the rebar in 3D in the ISM viewer.  However, when I try to update the Revit model from the repository, the the new slab does not have a property called "Rebars" when viewed in the Structural Synchronizer, and no rebar is created in the Revit model.
Is it possible to update a Revit model with rebar from an ISM repository?  If so, how?  Any direction would be much appreciated
1 REPLY 1
Chris.Aquino
in reply to: fbratton
As the code which handles the updating is written by a 3rd party, I would check with the creators of the ISM Plugin.
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
