Hi all,
When I render rebar, When render finish, I haven't seen any rebar.
Can anyone tell me how to make rebar visible in rendering?
I have check unobscured and view as solid as well as uncheck it in viewvisibily
But it doesn't work.
Thank you.
I got the same problem, it seems that there is no way to render the reinforcement bars...
What you can do is set the concrete material to be transparent.
Of course choose the desired texture for both the concrete and the rebar and all the other render settings (lights, exposure, etc)
You can use the interactive ray-trace to see the results live
When I want to show a picture of some 3D rebar, I use a 3D View where i turn on the "smooth lines with anti-aliasing" and "ambient shadows", use view filters to add color to the bars and override the concrete elements to make them transparent.
