Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
How to make Autodesk Revit run more smoothly with 8-core?
2 REPLIES 2
469 Views, 2 Replies
My computer has 8 cores. When the Autodesk Revit is running,
the computer shows that only one of the eight cores is processing.
The other seven cores are not being used at that time.
How can I use the other seven cores together to make the Autodesk Revit run more smoothly
and quickly?
My processor model number is Intel(R) Core(TM)i7 CPU  950 @  3.07GHz   3.07GHz
Looking forward to your soonest reply.
Best regards & Thanks,
Kevin
2 REPLIES 2
Which version are you running?
Then look at tht post http://revitit.com/blog/?p=443
DParkRMAK
Thanks for this link. I set all my cores to 100% and it made a significant improvement working with large models.
