My computer has 8 cores. When the Autodesk Revit is running,
the computer shows that only one of the eight cores is processing.
The other seven cores are not being used at that time.
How can I use the other seven cores together to make the Autodesk Revit run more smoothly
and quickly?
My processor model number is Intel(R) Core(TM)i7 CPU 950 @ 3.07GHz 3.07GHz
Looking forward to your soonest reply.
Best regards & Thanks,
Kevin
Which version are you running?
Then look at tht post http://revitit.com/blog/?p=443
@Anonymous wrote:Which version are you running?
Thanks for this link. I set all my cores to 100% and it made a significant improvement working with large models.
