Revit Structure
Revit Structure
Member
732861
Message 1 of 3 (237 Views)
How to make Autodesk Revit run more smoothly with 8-core?
237 Views, 2 Replies
11-06-2012 11:46 PM
My computer has 8 cores. When the Autodesk Revit is running,
the computer shows that only one of the eight coreis processing.
The other seven cores are not being used at that time.
How can I use the other seven cores together to make the Autodesk Revit run more smoothly
and quickly?
My processor model number is Intel(R) Core(TM)i7 CPU  950 @  3.07GHz   3.07GHz
Looking forward to your soonest reply.
Best regards & Thanks,
Kevin
Active Contributor
dhurtubise
Message 2 of 3 (236 Views)
Re: How to make Autodesk Revit run more smoothly with 8-core?
11-07-2012 02:30 AM in reply to: 732861
Which version are you running?
Then look at tht post http://revitit.com/blog/?p=443
Distinguished Contributor
DParkRMAK
Message 3 of 3 (186 Views)
11-19-2012 12:23 PM in reply to: dhurtubise
Thanks for this link. I set all my cores to 100% and it made a significant improvement working with large models.
