Not sure if this is a dumb question or not, but, how do I create stairs in Revit Structure (2014)? I've seen several tutorials that use the Architecture ribbon tab and from there go to a component creation dialog. And on those tutorials they have both the Architecture and Structure tabs. But I can't seem to find this Architecture tab on my ribbon. I just have Structure, Insert, Annotate, Analyze, Massing, Collaborate, View, Manage and Modify.
Is there a way to turn this Architecture tab on and off?
If the Architecture tab doesn't exist on Revit Structure, how to do you create stairs then? All I really need is a stairs material takeoff, not really looking to do any analysis on them.
Solved by gregamhale. Go to Solution.
If you use Revit 2014 Premium Product then you will get Revit Architecture, Structure & MEP (System) all in one. In Architecture Ribbon you will get "Stair" option to create a stair. Please find the attahced image file for your better understanding what i want to say.
Thanks & regards,
Subhradeep Sen
kolkata
India
Try looking in the Application Button (Big R in the upper left hand corner). Then go to Options -> User Interface and make sure the Architecture Tab is selected to be on.
Dear Misters
As long as I know Revit structure Tag do not have Stair Category. So we only have to creat in Archi Tag right? and after that make a component in situ by floor category we make a stair and delete Archi stiar and we got Structural stair , right? or is that method idk 🙂
