Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
How I can join Wall and slap
5 REPLIES 5
athurD
626 Views, 5 Replies
Hi All.
Have a good day. I am a new revit structure, I have a question : When I creative modol and check analyical wall and slap, But wall and slap don't join, I try with tools Align and join, But I don't do it.I have attachments a picture and file revit.Please help me, Thank verry much.
http://www.4shared.com/file/jLfnfCc0ce/Restaurant.html
5 REPLIES 5
athurD
in reply to: athurD
May you help me?
okapawal
in reply to: athurD
Basically, analytical slab and wall edge is automatically aligned with auto-detect.
Select the anlayticla slab.  Check, what is set at the Edge Horizontal Alignemnet settings?
What is the tolerance value set in the Analyticla Model settings?
Go to the Analyticla Adjust mode if you want to modify projuction manually.
Can you upload your model to Dropbox or A360 disk?
Waldemar Okapa
Sr Product Owner
athurD
in reply to: okapawal
THank you, Okapawal.
I was check with 2 way for you. But I don't do it. I have upload my model to Dropbox.
Link https://www.dropbox.com/s/3l0zrvhfw1dzj7m/Restaurant.rvt?dl=0.
Thanks.
okapawal
in reply to: athurD
I'm not sure which Revit version you use. I was trying to correct the model using RST 2013.
You can find the model on Dropbox:
https://www.dropbox.com/s/3bt58kk9jac32c6/Restaurant%20mod%202013.rvt?dl=0
Correcting manualy nodes position in the Analytilcal Adjust mode you can obtain a coherent analytical model.
Maybe there are still small incoherency along these curved edges.
Building structurla model you should keep in mind analytical one and simplify the geometry.
For example use straight segments instead of arcs.  Avoid small curbes on a floor boundary.
Waldemar Okapa
Sr Product Owner
athurD
Thank you verry much. I was successful. Good job THanks again.
