I have two projects: 1 = Main project and 2 = subproject.
The subproject is a precast beam which will be linked in de Main project. My problem is that the beam is horizontal in the subproject and slanted (angled) in the Main project.
How can I insert a revit link (sub project) on a slanted surface or refplane in my main project? Is that possible?
(I hope to find a better solution than rotating the beam an views in my subproject)
I am afraid this is not possible.
I assume you want to acheive to work in the flat/projected surface in the subproject and put all off that in the main project on a slanted ref plane.
Only thing I can think of is that you can use "Viewer" option when you set your workplane on the slanted workplane in Revit model.
Workflow (using your submodel or main model):
Drawing it "horizontally" in one model, than slanting that model in the other is not BIM, it's "cheating".
Hope it helps!
